1992 Dodge Dakota
MORENORAY
  • 1992 DODGE DAKOTA
Electrical problem
1992 Dodge Dakota V8 Four Wheel Drive Automatic
makes a clicking sound from fuse box under hood try to change fuses but did not work please help
Wednesday, January 27th, 2010 AT 9:17 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Are there any driveability issues? I need more info.
Wednesday, January 27th, 2010 AT 10:00 AM
MORENORAY
  • 6 POSTS
It clicks for about 15 minutes then it kicks in it sounds like a fuel pump under the hood. Then it starts
Wednesday, January 27th, 2010 AT 10:32 AM
JDL
  • 16,098 POSTS
Your saying, there is no starter action, when you first turn the key, to start position? I'm just trying to figure out if it cranks good and won't start, or it won't even crank?
Wednesday, January 27th, 2010 AT 12:20 PM
MORENORAY
  • 6 POSTS
The truck turns over fine. The fuel pump in the tank runs but it wont get fuel to engine until the clicking stops
Wednesday, January 27th, 2010 AT 2:04 PM
JDL
  • 16,098 POSTS
I found a picture of your relay box. By placing your hand on the suspect relay, maybe you can feel the vibrations when it is clicking, to pinpoint which relay. If there are multiple relays, sometimes, they are the same and you can swap relays. I can't see your relays from here, you have to decide if they are the same. If the problem is the wiring circuit to the relay, swapping won't help anything.
Did you check for trouble codes?
Wednesday, January 27th, 2010 AT 2:46 PM
MORENORAY
  • 6 POSTS
Good morning.I did check for trouble codes got a bad o2 sensor.I also changed relays. Could it be a bad brain
Thursday, January 28th, 2010 AT 7:31 AM
JDL
  • 16,098 POSTS
It could be about anything. Which relay is doing the clicking? If that is a heated 02 sensor, unplug it, see if it helps.
http://www.2carpros.com/forum/automotive_pictures/170934_dakota_relays_1.jpg
Thursday, January 28th, 2010 AT 11:06 AM
MORENORAY
  • 6 POSTS
Auto shutdown and fuel relay are clicking. Unpluged o2 sensor still nothing
Tuesday, February 2nd, 2010 AT 9:24 AM
JDL
  • 16,098 POSTS
I'd have to check the circuits for the coil side of relay, voltage and ground, your intermittently losing one or the other, not sure why?
Tuesday, February 2nd, 2010 AT 10:28 AM
