1991 Dodge Dakota fuel system problem
1991 DODGE DAKOTA
WVHOLLERMAN
Electrical problem
1991 Dodge Dakota 6 cyl Four Wheel Drive Manual
disressed over this issue i am about to describe any mechanic who can help will be greatly appreaciated.....
i have 091 dodge dakota 4wd club cab v6. i am having intermittant fuel problems. fuel pump is not running all the tiem but has been replaced
2 times in the past month. fuel filter has been replaced , fuel pressure reguator has been replaced, spark plugs an d wires have been replaced. internal distributor
parts have been replaced. can put gas in throttle body and truck will start. is not equipped wuth fuel temperature switch ( FTC ) or inertia switch. the fuel pump doesnot kick on when i turn on the ignition, there is no fuel is coming from the injectors when you turn ignition on or crank engine over.
as far as i can tell there is no fuel pump relay on the vehicle. according to haynes manual there is no relay on this model.however there is a auto shut down relay could this be the problem. i dont know if this would cause one to work a few days then shut down or not. as i stated before this is the second brand new fuel pump i have put on and the previous owner installed one also . all old gas has been replacdd that was in the vehicle prior to my possession also. it set as whilke with previous owner so i assumed it could have been a bad fuel pump cause by the old gas so i changed it. and changed it agian when problem started over after just a couple of days.
please help me figure this out. i can not get it to a garage to have it checked. please respond asap
wvhollerman@yahoo.com
Nov 22, 2009 at 1:49 PM
  • CERTIFIED EXPERT
Check and test or replace the Fuse D in the PDC and also ASD relay it powers both the fuel pump and injector if okay-the problem is with the computer
Nov 22, 2009 at 2:00 PM
