1991 Dodge Dakota Drive shaft fell off
MR.SCROOGE
Drive Train Axles Bearings problem
1991 Dodge Dakota 4 cyl Two Wheel Drive Manual na miles
My drive shaft fell off while driving and the wheels locked up. Could i have broke something by doing this ? and can i just put the drive shaft on and expect it to be ok ?
Feb 2, 2009 at 2:16 AM
BMRFIXIT
  • 19,053 POSTS
Drive shaft they don’t fall out for no reason
you need to find out why and fix it
and when you say the wheel locked up you mean that the rear end is frozen and ceased
or the truck just stopped and still can turn the rear wheel s?
Feb 3, 2009 at 1:14 PM
MR.SCROOGE
[quote:d23a755aed="BMRFIXIT"]Drive shaft they don’t fall out for no reason
or the truck just stopped and still can turn the rear wheel s?[/quote:d23a755aed]
a screw came unlose and it just fell off while driving. when the drive shaft fell off the rear wheels stopped turning.Im asking could i have hurt anything ?
Feb 3, 2009 at 8:12 PM
BMRFIXIT
  • 19,053 POSTS
put it back together and it all should be OK
check the shaft if bent or damaged
Feb 4, 2009 at 4:42 AM
