HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Suspension
Shock
Replace/Remove
1991 Dodge Dakota
JAYDEZZE
MEMBER
1991 DODGE DAKOTA
Suspension problem
1991 Dodge Dakota 6 cyl Two Wheel Drive Automatic
how do I change the rear shocks in my 1991 dodge dakota.
Tuesday, December 23rd, 2008 AT 3:30 AM
MECHANIC
Hi:
Replacing shocks on a dakota is straight forward. All you need to do is unbolt both the top and bottom, remove the shock and replace with new.
If you have any trouble, let me know.
Tuesday, December 23rd, 2008 AT 11:30 AM
Please
login
or
register
to post a reply.
Related Suspension Shock Replace/Remove Content
2002 Dodge Dakota Replacing Shocks
How To Remove And Replace Front And Rear Shocks
Asked by
daveprob
1 ANSWER
2002
DODGE DAKOTA
VIDEO
Front Shock Absorbers Ford F-150
Instructional repair video
GUIDE
Shock Absorber Replacement
An automotive suspension shock absorber is a normal maintenance item which requires replacement at regular intervals and can wear prematurely due to road conditions. There...
1992 Dodge Dakota Shock,spring Problem
While Removing The Left Shock, I Had The Lower Control Arm Jacked Up, (brake Calipers, Spindle, Etc Were Removed For Ball Joint...
Asked by
gatorchin
1992
DODGE DAKOTA
1990 Dodge Dakota Shocks
When Replacing Front Shocks On A 1990 Dodge Dakota, If The Top Nut Is Too Hard, Wont Come Loose And Keeps On Spinning What Can I Do To...
Asked by
mpexpresss
1 ANSWER
1990
DODGE DAKOTA
Ball Joints
Is It Possible That My Upper Ball Joint On Front Driver Side Is Worn Out With Only 45,000 Miles. Tc
Asked by
oldpan
2001
DODGE DAKOTA
Shock Replacement (Air) Mercedes Benz
Shock Replacement - Front
