1990 Dodge Dakota looses oil pressure when idling
200,000 MILES • V8 • 2WD • MANUAL
MICHELEWHATLEY
Over a year ago, had blown headgasket, shop said that truck ran too hot and had problems in the motor and motor would not last a year, well, truck is still running, but it looses oil pressure when idling, wether waiting on a red light or turning a corner, have replaced oil with non detergent 40 grade, but is there anything else I can do?
Jan 23, 2008 at 3:32 AM
2CARPRO JACK
  • 11,533 POSTS
Drop the oil pan and replace the pump and pick-up. Might have debris in the pick-up tube from when the heads were done, sometimes small pieces of material and engine gunk can fall into the engine and cause it to plug.Have you installed a manual gauge to verify that it is losing pressure? Aside from that..... Valvoline straight 50w racing oil is pretty thick
Jan 23, 2008 at 11:59 PM
