1989 Dodge Dakota Stripped bolt that holds the front disc b
1989 DODGE DAKOTA
MAAGEE036
Brakes problem
1989 Dodge Dakota 6 cyl Four Wheel Drive Manual ?????? miles
What is the name of the part that the front disc brake caliper is attached to? One of the holes that that the caliper bolt goes in is stripped out, and I would like to replace it. I checked a machine shop nearby and they want 75 bucks to drill tap and put a threaded insert in the stripped hole. If a new one is priced some where in the ball park I would rather have it.
Feb 3, 2009 at 12:34 PM
BMRFIXIT
  • 19,053 POSTS
check with your local part store they should have an over size bolt that you can use with out any drilling and or taping and its about $15 to $20
check it out
Feb 3, 2009 at 1:04 PM
