1989 Dodge Dakota ..240 degrees overheating?
SCOOTER567
  • 17 POSTS
Engine Cooling problem
1989 Dodge Dakota 4 cyl Two Wheel Drive Manual 105k miles
After replacing a bad water temp guage, my temp guage now reads a constant a 235-240 degrees, but never boils over. Tried another guage, same thing. Hooked up radiator fan to run constantly, made no difference in temp. Should I worry about it on such an old truck ?
Roger
Apr 8, 2010 at 1:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
so long as it doesn't go over and stay above 240 will be OK.
Apr 8, 2010 at 2:19 PM
SCOOTER567
  • 17 POSTS
I also replaced the old thermstat with a 192 degree thermostat. Sure looks like it is opening & closing when the temp goes from 240 down to 235 degrees. At what temp could I expect it to boil over & leave me stranded beside the road ?
Roger
Apr 8, 2010 at 11:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
may want to try a cheap mechanical water temp. gauge to see if its even reading accurate. if it is truly at 240 constant then that is a bit warm, running at 260 or higher would most likely boil the coolant
Apr 9, 2010 at 4:35 AM
SCOOTER567
  • 17 POSTS
That 240 degree reading is with a AZ mechanical guage. My factory installed guage was very erratic & all over the dial.
Thanks,
Roger
Apr 9, 2010 at 7:45 AM
