1988 Dodge Dakota warms up and wont run.
NURDGURL
  • 1988 DODGE DAKOTA
Engine Mechanical problem
1988 Dodge Dakota 6 cyl Two Wheel Drive Automatic
i start the truck, and it runs fine, but as soon as it warms up, it dies, and wont restart. It just turns over. But will always star the next morning when its cold.
Monday, September 7th, 2009 AT 8:23 AM
  • 109,885 POSTS
When it doesn't start, did you check to see if the engine is getting spark and fuel to the engine?
Wednesday, September 9th, 2009 AT 10:00 PM
MIKE H R
  • 3,094 POSTS
When has the fuel filter been changed. Had the same thing happen to my wifes ford truck and found that the fuel filter was mostly clogged up. After running a little while the dirt would cause the filter to clog thus stopping the fuel from reaching the engine. Once it sat for some time the dirt wouls settle from the filter and the problem would do it all over again. First check the fuel filter and replace.
Wednesday, September 23rd, 2009 AT 10:55 AM
