1988 Dodge Dakota truck not charging battery
64,000 MILES • 4 CYL • 2WD • MANUAL
TURBO5.9
I was wandering if you can direct me to find a fusable link on my 88 dodge dakota. I have been told that the fusable link is likely to burnt out. I have put a new regulator on the truck and have had the alternator tested on the truck. I have also installed a new battery on the truck. I can charge the battery and can drive the truck for a couple days until the battery runs dead and have been told that the fusable link in the wiring has been burnt out
Jan 25, 2009 at 2:15 PM
DOCFIXIT
  • 18,828 POSTS
Check black wire on alt if no power then look off batt positive to several fuse links. Can ID they will have a red/orangelarger c connector on wire. Check black one.
Jan 26, 2009 at 4:57 AM
