1988 Dodge Dakota LE v6 fuel injected
JERSEYCOUGAR
My dakota just started dying while driving,can wait few minutes restarts,will do so in driveway.Am elderly mileage is around 73k original know for fact! Notice exhaust moisture is loaded w/ black carbon smells good when starting cold. Have no code reader only indication is when engine dies only light is oil light no bucking no back fire?Broad coverage Chilton book no real help was dealer maintained and in tip top shape w/ orignial tags showing. Most garages w/ computer reader want $50 just to hook up to computer,retired and wondering if simple cure w/ ethanol gas or what?
Jan 2, 2007 at 1:34 AM
STRATUS98
  • 96 POSTS
your codes can be read for free at some auto parts stores, and they print you out the codes being thrown and you can check them out here. When it dies does it hesitate to start back up? It is a tough thing to diagnose without more information
Jan 7, 2007 at 3:13 PM
JERSEYCOUGAR
[quote:4c6281bcbd="stratus98"]your codes can be read for free at some auto parts stores, and they print you out the codes being thrown and you can check them out here. When it dies does it hesitate to start back up? It is a tough thing to diagnose without more information[/quote:4c6281bcbd]Had spark,fuel came thru flow back hose cranking had some water in it,changed fuel filter under frame and added HEET water remover bounced truck,it did it prior to change (stalled)then ran normal?? Seems okay will add catalyptic cleaner and use locally to see if cured??
Jan 7, 2007 at 11:29 PM
