Drive Train Axles Bearings problem
1988 Dodge Dakota 6 cyl Manual
Hi.
The clutch in my Dakota will only release when the pedal is pressed hard to the floor.
Checked the fluid and it was down but only barely and the pedal never felt sloppy, topped it off (needed a tiny splash), no difference.
My question is the slave cylinder, per the Haynes manual it says the whole system must be swapped out (clutch master cylinder lines etc) because it a complete unit and bled at the factory. True? Can I just replace the slave cylinder as the parts show online to be seperate parts?
Thanks for any help you can provide!
Gordo1
Hi.
Gordo1
Jul 21, 2009 at 12:46 PM
