removal and installation of ignition lock
STEF4734
Electrical problem 6 cyl Two Wheel Drive Automatic 100000 miles
I need to replace the ignition lock cylinder and have removed the steering wheel and the turn signal hazard warning switches. My manual shows a lock release slot which I cannot find.
Jan 22, 2010 at 10:31 AM
  • 55,676 POSTS
You will need to remove the steering wheel before you begin. Here is a guide to help you see what you are in for but yours will need a puller
https://www.2carpros.com/articles/steering-wheel-removal
Here is some guides that show you how to change the ignition lock (below)
Please let us know what happens so it will help others.
Cheers, Ken
Oct 18, 2017 at 8:19 AM
ILB1211
Replacing ignition switch on 94 dodge dakota
Oct 18, 2017 at 8:20 AM (Merged)
CARADIODOC
  • 34,413 POSTS
What's the question? Did you check for overheated terminals in the electrical connector?
