1987 Dodge Dakota Can't pass emissions
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAKOTAGUY
Ok. I'm in a bind here. I've got a 1987 dodge dakota work truck I just bought, but it keeps failing emissions inspection. I don't think it has a computer to pull codes from, so I'm just guessing at this point. The original exhaust pipe broke off at the muffler so I've got one clamped on. No check engine light. The emission test says I'm too high on HC and CO. I just put new spark plugs in it, but I still have to warm it up good in the mornings. Can anyone please tell me what I need to do to pass inspection. Muffler?Cat?sensor?
thanks!
Feb 1, 2010 at 5:51 AM
  • 110,244 POSTS
Here is what I need you to do:
1) with the engine OFF, cycle the key from off to on 3 times. On the 3rd time, let it in the run position.
2) The check engine light should begin to flash.
3) Count flashes. In this year, trouble codes were 2 digit numbers. Thus, the light will flash, pause, then flash again to give you the 2 digit trouble code. Count the number of flashes each time. Between codes, there will be a longer pause. When it finishes, the final code will be 55.
Feb 2, 2010 at 10:41 PM
