1987 Dodge Dakota
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREGTWISTED
how do i run manual codes useing the check engen light
Jan 23, 2009 at 12:36 PM
  • 110,244 POSTS
Hi:
It's done with the ignition key. At no point will you start the engine. With the key off, cycle it three times from off to the run position. On the 3rd time, leave it in the run position. All codes will be 2 digits. The light will flash one number then a slight pause then start the next number of the double digit number. Keep track of the blinks.
Jan 24, 2009 at 2:42 PM
COWDOUGH
turn the key to the run position (forward) and back 2 times...then leave it in run on the third click forward...so flick to run...back...run....back...run..then leave it...do this within 5 seconds...get out your repair manual..it will have all the codes in it.
Apr 10, 2009 at 3:06 AM
