1965 Dodge Coronet Distributor cap plug wire orientation
75,000 MILES • V8 • 2WD • AUTOMATIC
JZXPK2
Which terminal on my 318's distributor cap would be considered number 1. I believe it's to the 1st one to the left of the vacuum canister (based on the distributor turning clockwise). I'm not sure but I believe I'm one before that, making it 2 befire the canister. I've heard a lot of people say that this doesn't make a difference but I believe it does in regards to where my timing would be significantly off. The car runs, but seems quite "flat" under acceleration.
Thanks!
Jul 24, 2009 at 6:39 AM
HMAC300
  • 48,601 POSTS
#1 is at the very front of the cap, 2 positions from the clipon the right side of the engine. In otherwords at the 12:00 position. It fires clockwise 1-8-4-3-6-5-7-2. You might check to see if your timing chain is bad. bring the engine up to #1 at balancer and match with cap. Also if you have low compression on all cylinders that is good indication as well.
Oct 24, 2009 at 6:26 AM
