1994 Dodge Colt Wheels and Brake Shake
85,000 MILES • 4 CYL • FWD • AUTOMATIC
ONESHOTTED
Hi, i have 2 different problems. I just bought some new aluminium mags for my car. They balanced them before installing. Now, when i go faster than 110km/h, i can feel a little shaking in the sterring wheel, that amplify if i go faster. My wheels have been balanced again and the problem will persist.
The second problem is when i push the brakes, the brake pedal will shake and this is very annoying. The brakes are new front and rear. Front are disk, and rear are drums, only the drums are not new. the brakes inside are.
Apr 26, 2008 at 2:13 PM
BUZZSAW
  • 1,198 POSTS
[quote:5365d932a8="Oneshotted"]Shakes or Wobbles problem
1994 Dodge Colt 4 cyl Front Wheel Drive Automatic 85000 miles
The second problem is when i push the brakes, the brake pedal will shake and this is very annoying. The brakes are new front and rear. Front are disk, and rear are drums, only the drums are not new. the brakes inside are.[/quote:5365d932a8]
first prob: the wheels are not ballanced right or your tie rods are bad. if it didnt do it before the wheels need to be balanced somewhere other than where your taking it
second prob: did you just put pads on it or do a full brake job with rotors being turned, sounds like the rotors or drums are warped
Apr 26, 2008 at 3:06 PM
ONESHOTTED
thanks a lot for the answer.
For the wheels, i suspect those mechanics to make a bad balancing job... They did not installed a centering ring with the mags, can this be a cause to the shaking at high speed?
For the brakes I just changed pads, i don't know if they turned rotors or changed them but i don't think so. The drums are rusty so they never changed them.
Apr 26, 2008 at 3:58 PM
BUZZSAW
  • 1,198 POSTS
[quote:4009c328eb="Oneshotted"]thanks a lot for the answer.
For the brakes I just changed pads, i don't know if they turned rotors or changed them but i don't think so. The drums are rusty so they never changed them.[/quote:4009c328eb]
I personally never turn the drums they can warp but it is unlikely, I just go over them with sand paper, as for the rotors there probally too thin to turn if there warped
for the wheels they just could have static balanced them its not a true balance depending on your wheels
Apr 26, 2008 at 6:56 PM
