1993 Dodge Colt won't start
1993 DODGE COLT
LEH4
Engine Mechanical problem
1993 Dodge Colt Front Wheel Drive Automatic 120000 miles
i try changing the starter, check the fuses, wires. i just don't know what it can be. need help. last i drove it, was on a rainy day. i drove a road pretty fast and water must the splash in under the engine. since then it won't start. when i turn the key it seem like the starter is dead. but i try that already. need help.
Sep 7, 2010 at 8:36 PM
No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, transmission position switch and ignition switch assuming the battery and connections are good.
Sep 8, 2010 at 2:44 AM
