1993 Dodge Colt Car Cranks but won't start
35,000 MILES • 4 CYL • AWD • MANUAL
BILLYJOCRAIG
Ok I have a 1993 Dodge Colt and it is a manual I was drivin it one day and then it quit it wouldn't start or anything. So I replace the distrubitor cap, spark plugs, oil, radiator fluid, timing belt, and put gas in it and it is full cause I filled it full at the gas station, I did all that but when I go to start it it cranks but dosen't start. What is my problem? Please help me.
Oct 6, 2009 at 11:09 AM
  • 75,988 POSTS
Hi there billyjocraig and TY for the donation this is what keeps the site going
No start condtion -do below and report back with some results so that we can continue to assist you in this matter.
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Oct 6, 2009 at 11:42 AM
