I've had this colt for years and am unable to make it run when i start it it will rev up decent but not quite right and wont idle on its own but when it warms up it will idle but wont rev without being pumped. my distributor went out awhile back and i changed and it ran good a couple of months then started running rough like now I have changed comp., tps, mass air flow, distributor, o2 sensor, i took the catylitic converter out and i cheanged all the vacuum hoses i could find i only found like three behind the motor. I need some serious help i havent found a shop that could give me a answer the only thing i havent checked is fuel pressure and i do not have a check engine light on
Sep 10, 2009 at 7:43 AM
