1992 Dodge Colt fuel injectors
81,000 MILES • 4 CYL • FWD • MANUAL
HAWKEYE54
the injectors are not getting any fire , where do i start.
Jun 29, 2009 at 12:42 PM
CH112063
  • 1,320 POSTS
The fuel injectors are controlled by the powertrain control module. It controls injector circuits with pulse width to ground circuits internally. Check all the engine compartment fuses, then use a scan tool to test and service the fault with the fuel management system. ok, you need to use a computer to communicate with a computer for service and fix. Codes?
good luck and hope you get it repaired ok.
It is a trained professional job who uses these specialized tools and procedures first, then gets tough second.
Don't ask about 3rd please. just kidding. CHECK Engine compartment fuses in power distribution center.ok
Sep 27, 2009 at 6:34 AM
