1992 Dodge Colt 1.5 Dodge Colt running rich/rough
RCODENEWF
Engine Performance problem
1992 Dodge Colt 4 cyl Front Wheel Drive Manual 260K miles
I'm working on my son's 92 colt with the 1.5 mitsu engine.
Engine died a week ago at which time I checked and no spark. I replaced it with a new/not reman distributor which has the coil etc built in.
Car fired right up.
Set the timing as per spec.with wire grounded.
Problem:
Rough/low idle
Hunts
While holding the throttle at @1500 the engine sounds like it's detonating. By retarding the distributor while holding the rpm I can kill the detonation noise.
Plugs are brand new just installed with 0 miles. Running for 10 minutes or so the plugs are sooty.
Compression is 175 on all 4.
Timing belt is not new but I checked all marks and they line up perfectly. Sooty condensatioin coming out of tail pipe.
No cracked hoses. It doesn't have an EGR.
Any ideas?
Thanks....John
May 29, 2008 at 6:40 AM
  • 110,248 POSTS
John:
Is there any smoke from the exhaust? Also, have you checked the temp sensor?
Mar 10, 2009 at 1:21 AM
