Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Colt
Drivetrain
CV Axle
Replace/Remove
1992 Dodge Colt
1992 DODGE COLT
JIMMYPHELTON
MEMBER
1992 Dodge Colt Front Wheel Drive Automatic
replacement of passenager side alxe
Jan 24, 2010 at 10:31 AM
CH112063
Experienced Mechanic
Put the frame(uni-body) on jack stands, loosen the sway bar, remove the lower ball joint nut(17mm) or 19, and pry it down. Pull the whole axle and bearing outward to remove and replace either axle. Watch for a C-clamp in the trans. OK thanks
Apr 28, 2010 at 3:05 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
