1991 Dodge Ramcharger No Crank Clicking
CLIFF JACKSON
My 91 Dodge Ramcharger 360 5.9 liter would not start this morning. I replaced the starter but it still will not crank. The battery is fully charged but all I get is a clicking when I crank it. any suggestions????
Feb 25, 2006 at 12:41 PM
JPAM
  • 307 POSTS
check over your battery cables..(From Battery to starter and grounds)making sure that every thing is connected good and nothing coroted.. & make sure battery post are clean..
Feb 25, 2006 at 12:46 PM
Suggested Repair
Inspect the battery cables from the battery to the starter and all ground connections. Confirm every connection is tight and free of corrosion, and clean the battery posts.
Conversation Summary
The owner of a 1991 Dodge Ramcharger with a 5.9L 360 says it will not crank. The starter was replaced and the battery is fully charged, but turning the key only produces a click. The expert advises checking the battery-to-starter cables and grounds for secure, corrosion-free connections and cleaning the battery posts.
