2009 Dodge Charger Steering
37,000 MILES • 6 CYL • 2WD • AUTOMATIC
THRILL1
I'm have major steering issues in my Dodge Charger. I took it back and got the Rack replace and it drive great for two weeks. After two weeks the steering felt very loose and the car is hard to control no matter what speed I drive it at. I got the front tires replace and now the car is damn near impossible to drive. The dealship and dodge told me the car wanders back and forth and seems loose because it is rear wheel drive and I have to get use to it. Im paying 566.00 per month on a car that has major steering issues. Do you have any idea as to what it could be. Its dangerous for me to drive in the rain and at high speeds.
Oct 10, 2010 at 2:00 PM
AB1975
  • 15 POSTS
you need to take it to a different Dodge dealership and get a second opinion. Don't tell them you already went to another Dodge dealership.
Your vehicle should still be under warranty, correct me if I'm wrong? They need to fix it. Period.
If you cannot control your car, that's a problem. I've driven rear-wheel drive vehicles before (with big engines, mind you) and never had that type of problem.
I believe when they replaced your rack, they did not adjust it properly or it is defective or something else in the steering needs to be replaced/adjusted. Good luck. And, HOLY car payment, Batman!
Oct 12, 2010 at 9:18 AM
