2008 Dodge Charger engine light
KENYAB
2008 Dodge Charger Automatic
Hello.....I had my car ck'd on the machine....the error code was P1004 (intake manifold air control vial performance). I'm trying to find out what exact part do I need, so I can have it fixed.
Thank you
Jan 23, 2010 at 2:20 AM
ERNEST CLARK
  • 1,730 POSTS
First, I'd need to know which engine you have. (v-8, v-6)
The proper name for the component you're referring to is "Variable Induction Control ValveAlso", but it's also called a "Short runner valve"
Now, just because you got that specific code (P-1004), doesn't mean that component is defective.
This is a solenoid, that when activated by the computer, opens up an extra passage inside your intake manifold. At high engine speeds, this allows your engine to breath better, thus providing more power.
You issue could be with the solenoid, connector, wiring, or the computer itself.
You need to test each part of this system in order to find your guilty party. If you just begin replacing components, you'll soon find out the hard way that this never works.
Mar 17, 2010 at 4:57 PM
