2007 Dodge Charger Temperature guage has its own personalit
2007 DODGE CHARGER
96,500 MILES • 6 CYL • 2WD • AUTOMATIC
FARHANMALIK123
I have a 2007 Dodge Charger V6 2.7L. It's about to reach 100k miles. Is there any specific service that i should get for it's 100K?
Its working fine. I recently had problem with the temperature guage, it sometimes have it's own personality, it refuses to move from "C" somtimes when I start the car in the morning, but starts working after i drive a couple of miles, and at the same time give the red light in the dash looks like a thunder bolt in brackets.
I think it's for a weak battery,but other dan dat there are no signs of a weak battery.& a few days ago i was on highway and the temperature guage started rising from it's normal position(which is usualy in the middle of hot and cold) towards the hot. I turned the car off and examined the engine. I found anti freeze leaking on a pipe where its joined to another pipe( i guess where it goes in the engine),may be the seals needed to be replaced or something?can you guide me? shud I take it to dealer.how much it cost?i am not rich.
Jun 9, 2010 at 3:36 AM
HMAC300
  • 48,601 POSTS
if you take it to any service garage they will be cheaper than the dealer usually and will tell you what it is and how much to fix it.....
Jun 16, 2010 at 12:22 PM
