2006 Dodge Charger wont go into gear
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
BEN54
my car will not get out of park into gear
May 24, 2010 at 4:59 PM
BRIZIELINS
  • 6 POSTS
Did you hear any unusual noises before this happened? Do you have brake lights? If not check fuses with test light ,also check brake light switch they could cause your shifter safety lock not to function.
Jul 1, 2010 at 6:52 PM
  • 75,988 POSTS
Or you have a shift interlock control system problem such as the shift control solenoid after brake switch/fuse is rule out
Jul 1, 2010 at 6:55 PM
