2006 Dodge Charger turn signal, cruise controll, horn. do n
2006 DODGE CHARGER
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
JANDRO509
ok well for some reason the turn signal, crusie controll and the horn do not work. i have checked all the fuses and they seem to be fine. i went to autozone and they said its a circut braker that went bad. im not sure where it is located or how i can fix it. can you help me.... thanks
Dec 21, 2009 at 6:34 PM
RACEFAN966
  • 5,029 POSTS
There is no circuit braker in you car for the turn or the horn. Now what does control this is the what Dodge calls the front control module (FCM). Fuse 4 and 8 feed power to module so just double check those otherwise you may need a new one. Now fuse 8 sends power to the park light relay and that powers the FCM. If you have a digital multi meter we can do some tests to see if it is the relay or the module.
Dec 23, 2009 at 2:29 AM
