2006 Dodge Charger starter
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
KRISTOFFX3
when i attempt to start the vehicle, all the power comes on but there is no attempt for the vehicle to turn over. the only noise is a clicking from the trunk which has the fuse box in it. that starter doesnt make any noise at all. ive checked the fuses and they are good. what else should i check before i have to take it in acutally?
Feb 7, 2009 at 1:33 AM
  • 110,248 POSTS
Check the starter relay. Also, have a helper turn the key to the start position while you check to see if there is 12 volts to the smaller wire on the starter.
Let me know what you find.
Mar 6, 2009 at 11:04 AM
BOWTIE316
I have an 06 Charger with the 5.7 and it is doing the same thing. Did you figure anything out?
I have swapped relays and checked all the fuses, still nothing. I can jump across the starter and it engages fine. Any ideas? I need to get a wiring diagram.
Aug 19, 2009 at 7:54 AM
