2006 Dodge Charger Front brake rotors
32,000 MILES • V8 • 2WD • AUTOMATIC
MARKA615
Can you tell me how to remove my front rotors? I understand about removing the calipers, and the two metal washers that are on the studs from the factory, but still can't get the rotors removed. Can you help please? Thanks
Aug 6, 2008 at 4:29 PM
  • 110,248 POSTS
Hi:
If you removed the caliper and the factory clips, the rotor should come off. Tap on it with a rubber mallot to see if it comes loose. It may be tight from corrosion.
Mar 6, 2009 at 1:27 PM
