2006 Dodge Charger flood?
2006 DODGE CHARGER
70,000 MILES • V8 • 2WD • AUTOMATIC
RTURZI
hey, I recently pushed my car out of about a foot of water and then once i reached higher ground, i tried to start my car, not realizing this was bad i continued to try to start it until i heard a small cracking sound and the car altogether stopped trying to start, also the car began to leak what looked like oil. please help, what is possibly wrong with my car?
Sep 30, 2010 at 1:57 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Check that the air cleaner is not wet with water, if so you may have ingested water into the engine, pull the plugs and crank it over to see if any water is in the cylinder, do this with caution nas any water will be ejected with force, drain the sum and check for water in the oil, start here and report your findings.
mark (mhpautos)
Sep 30, 2010 at 2:56 AM
