2006 Dodge Charger
35,000 MILES • 6 CYL • 2WD • AUTOMATIC
06CHARGER06
my cars right front end dips when turning left. also the steering has play but only when turning left. when turning right the steering is perfect. in addittion to that, i hear a popping sound on the right side of my front end when i go over big bumps or turn the vehicle. brake dust builds up fast on that wheel also. what could be the problem!?!?
I replaced the steering rack..shock...tension control arm...the suspension was inspected 3 times.
Jun 21, 2009 at 4:50 PM
SERVICE WRITER
  • 9,123 POSTS
Does the brake hose get restricted or collapsed when turning? Compare the two sets of pads between the two front wheels. IF one side is worn more, look for a caliper or brake hose problem on that side. Caliper may be loose? Not sure what you mean by there is steering play when turning left. Call the service dept at the dealer regarding a saftey recall for this:
https://images.2carpros.com/forum/automotive_pictures/30961_recall_1.jpg
Jun 21, 2009 at 10:05 PM
