1973 Dodge Charger oil pressure
1973 DODGE CHARGER
STONE844
Engine Mechanical problem
1973 Dodge Charger V8 Two Wheel Drive Manual
what is the normal idling oil pressure for a new rebuilt 340 engine with a high volumm oil pump?
Mar 6, 2009 at 11:46 PM
2CARPRO JACK
  • 11,533 POSTS
That would depend on how loose the engine was set up (bearing clearances) and what weight oil is being used.At idle hot, I would think 15+ psi is more than enough as long as it goes up with engine rpm's.
Mar 6, 2009 at 11:53 PM
