1972 Dodge Charger charging system
1972 DODGE CHARGER
999,999 MILES • V8 • 2WD • AUTOMATIC
GIANTSBANE
My alternator checks out good when tested, however it is not sending the charge back to my battery. When the car is running I have a drain. I have tested the voltage from the regulator to the alternator and it is consistant.
Oct 25, 2009 at 10:02 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
the voltage is consistant? what volts? Is the battery any good. If it's not you will have an alternator problem. charge teh battery and take it to an auto parts store and have them check it.
Nov 15, 2009 at 3:00 PM
