1971 Dodge Charger
CHARGER09
Engine Mechanical problem
1971 Dodge Charger V8 Automatic
i have a new battery and a new starter on a 1971 dodge charger, but it still wont turn over. any suggestions on what to check next
Mar 21, 2010 at 8:30 AM
  • 75,988 POSTS
If its not cranking-you might want to test the neutral safety switch, and if it has a starter relay check that too and also test the ignition switch
Mar 21, 2010 at 9:15 AM
CHARGER09
Thanks for the tips. Ill give it a try and see how it goes
Mar 21, 2010 at 3:10 PM
CHARGER09
Could my distributor be causing my car problems. It wont crank when i turn the key. It simply makes a light popping noise and it sounds like its coming from the distributor so could my distributor have gone out and caused my engine not to crank
Mar 23, 2010 at 2:18 PM
