Engine Mechanical problem
1971 Dodge Charger V8 Automatic
i have a new battery and a new starter on a 1971 dodge charger, but it still wont turn over. Any suggestions on what to check next
Sunday, March 21st, 2010 AT 3:30 PM
MECHANIC
If its not cranking-you might want to test the neutral safety switch, and if it has a starter relay check that too and also test the ignition switch
SPONSORED LINKS
Sunday, March 21st, 2010 AT 4:15 PM
CHARGER09
MEMBER
Thanks for the tips. Ill give it a try and see how it goes
Sunday, March 21st, 2010 AT 10:10 PM
CHARGER09
MEMBER
Could my distributor be causing my car problems. It wont crank when I turn the key. It simply makes a light popping noise and it sounds like its coming from the distributor so could my distributor have gone out and caused my engine not to crank
