2001 Dodge Caravan Check Engine Light
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
COOKS12330
Check Engine Light came on. Code was diagnosed at AutoZone Parts Store as being evaporative loss alarm and advised that gas tank lid liikely cause. I replaced lid with a locking one and removed the battery cable for about ten minutes to cancel the check engine light alarm. Check Engine light stayed unlit for a few days and then came back on. Is removing the battery cable the best way to cancel the Check Engine Light alarm or is there perhaps another evaporative loss other than the gas tank lid that is triggering the Check Engine Light alarm? I cannot detect any change in engine performance nor change in economy since the check engine light came on.
Sep 29, 2008 at 3:22 AM
LILWILLS
  • 49 POSTS
yea that is a way t clear it but i would replace the gas cap with an oem part and make sure its tight everytime u get done addin gas. also there are a couple of rubber emmissions hoses under the vehicle where the driver sits if they are cracked they need to be replaced
Oct 30, 2008 at 3:08 PM
