temperature light on 1997 Dodge Grand Caravan AWD
CLEENMAN
I have a 1997 DGCaravan AWD with 97,200 miles on it. It is a V6.
My wife was driving it when the service engine soon light came on. She said after that the temperature light came on a "bell noise" started.
I met her & checked the reservoir, which was very low. I filled it & restarted the car. The service engine light stayed on, but the temp light went off. The temp gauge went down to 1/2 & I started to driveit home.
The gauge began to climb agai & then the temp light came on again. I stopped the vehicle & checked the reservoir, which was full. I don't see any leaks anywhere on the block or around the hoses.
Aug 5, 2007 at 12:33 PM
MERLIN2021
  • 17,250 POSTS
See if the coolant is circulating...if not check the thermostat, the water pump. If you can pressure test the system.
Aug 11, 2007 at 10:28 AM
