speed sensor?
DADDYJOJO35
  • 5 POSTS
:? hey I have a problem. I have a 96 grand caravan 3.3. won't shift out of first, and the speedometer stoped working at the same time. I researched this on this site and the answer seemed to be the speed sensor. problem is when I got to the part store they asked which do I need the input or the output.now I am lost again. The speed sensor seems like the answer but which one? :?: There also seems to be one other part that looks like your clasic speedometer cable end with a plug and wire on the side the cable would usualy be. :cry: please help I have 4 kids and this the only vehicle I can take them all in UP DATE* JUST TRIED OUT PUT SENSOR NO HELP. :cry: :cry: :cry: ANYTHING ELCE?
May 28, 2006 at 7:53 AM
VANDRAGON
  • 298 POSTS
it's the output speed sensor.
May 29, 2006 at 3:12 AM
RACHAELH
my van did same thing and i did replace both in and output speed sensor unfortunately neither one helped also replace transmission module and pcm and that did not help either. just thought i would let u know. curious if u ever got it figured out as i am having same problems?
Aug 26, 2008 at 3:46 AM
