Rotors "Casting Problem"
MAESTRO23
We own a Dodge Caravan. We have had it for some time now and until recently our brakes have been fine. We noticed some pulsating when applying our brakes and took them in to have them checked. We were told we would need new pads and the rotors needed to be machined. We were fine with that.
When we picked up the van the mechanic told us that the rotors were "not true flat due to casting". He mentioned that there was some pulsating still but it should be better than before. WAS HE WRONG!!! The brakes feel like there is a large rock attached to the rotors now and we have a THUMP THUMP THUMP rather than a whoosh whoosh whoosh. It is horrible and much worst now.
Is it possible to have a casting problem in the first place? If it is, is it possible to go from a soft pulse to a hard jerking after the rotors were machined or turned? Or is this some claim that a mechanic makes for a someone who has no knowledge?
Thanks for any guidance you may provide.
Jul 27, 2007 at 8:01 PM
CLY
  • 308 POSTS
I have had some rotors that the specs were good on and I attempted to resurface them and they were just a pain to cut. They would chatter and dull bits on the brake lathe really quick from the rotors being so hard from constant high temps. I have also seen where the rotors would get rusty from the vehicle setting and not be able to be resurfaced. Is the Pulsation coming from the front? Did they do anythng to the rear brakes? Do you know if the rear brakes are drum or disc?
Cly
Jul 27, 2007 at 9:42 PM
