1996 Dodge Caravan Stalls and Won't Restart
GMAJER1966
my 1996 dodge caravan se 3.0 l with 126000 miles was running fine at about 25mph. suddenly the engine just shut off. i tried to restart and nothing but engine turning over and over. i replaced catalytic converter aprox. 3000miles ago. i thought perhaps the fuel pump. is there any way to confirm this or any other possibilities? i do notsmell any fuel when hood opened. and i sprayed starter into the intake w no results.
May 29, 2006 at 4:10 AM
DAVE IN WPG
  • 10 POSTS
well try this and if fail`s then it will be your fuel pump!!!
get in the vehicle and roll up the windows and listen very carefull and you should hear a buzzing noise coming from the back of the van this meaning your fuel pump is working and if not your fuel pump is the problem or a fuse check everything before u install the pump as these can be very expensive
take-care
dave in wpg
May 29, 2006 at 4:59 AM
SDALTON19
  • 87 POSTS
also to verify that the pump is faulty alot of times i have taken a hammer and hit the tank not really hard so as to damage anything but hard enough to jar the pump try this if the vehicle starts you know its the pump and you wont need to check anything electrically
May 29, 2006 at 6:01 AM
DAVE IN WPG
  • 10 POSTS
yes this will also let one know if the problem lays here i have had this once and hit the damm beast in the butt and yes it started and was the guilty culprit
dave
May 29, 2006 at 6:53 AM
Suggested Repair
Listen at the rear with the windows up for the fuel-pump prime buzz. If it is silent, check the fuse and related electrical items before replacing the pump. A firm tap on the tank that makes the engine start also indicates a failing pump.
Conversation Summary
A 1996 Dodge Caravan shut off at about 25 mph and then only cranked. The owner smelled no fuel and got no response from starting fluid in the intake after a recent catalytic converter replacement. Replies recommend listening for the rear fuel-pump buzz, checking the fuse, and tapping the tank; if it then starts, the pump is likely faulty.
