Fuel leak
STAU1RIC
Hello, I have a 1996 Dodge Grand Caravan 3.0L with about 160000 miles on it. Runs fine, but once it got cold, around 0, I noticed a gasoline smell. Now this morning I noticed a good sized puddle of gasoline on the floor by the right front quarter. I'm guessing fuel line, but where do I start? Thanks for any help.
Jan 31, 2007 at 12:57 AM
BOOTDOG
  • 665 POSTS
what you need to do is get the vehicle on some ramps or jack it up, while you're looking with a flashlight around the area where the puddle is, have someone else turn the key to the on position to cut the fuel pump on. by doing this you should see where the fuel is leaking from, (i.e. a line)hope the info helps
Jan 31, 2007 at 10:15 AM
