1991 Dodge Caravan Rough Idle No Power
DNR79065
  • 6 POSTS
I have a 1991 Dodge Caravan ES 3.3L engine with 222.060 miles on it. The Engine will sometimes run a little rough and will not get power or shift on acceleration almost like the transaxle is the problem but after a few seconds or minutes this problems fixes it's self and the van runs and shifts fine. But it does reoccur. We have changed out the Output speed sensor and this weekend we are going to change the input speed sensor and change the distance sensor also on the Trans. Today we are going to replace the PCV valve. please can you tell me if we are on the right track with this. :?
Mar 12, 2007 at 12:26 PM
  • 75,988 POSTS
[quote:3fae73bc61="dnr79065"]I have a 1991 Dodge Caravan ES 3.3L engine with 222.060 miles on it. The Engine will sometimes run a little rough and will not get power or shift on acceleration almost like the transaxle is the problem but after a few seconds or minutes this problems fixes it's self and the van runs and shifts fine. But it does reoccur. We have changed out the Output speed sensor and this weekend we are going to change the input speed sensor and change the distance sensor also on the Trans. Today we are going to replace the PCV valve. please can you tell me if we are on the right track with this. :?[/quote:3fae73bc61]
When was it last major tuned-up?
Could be the VSS/TPS/MAP sensor.
Mar 12, 2007 at 12:34 PM
DNR79065
  • 6 POSTS
[quote:0085dc34a3="rasmataz"][quote:0085dc34a3="dnr79065"]I have a 1991 Dodge Caravan ES 3.3L engine with 222.060 miles on it. The Engine will sometimes run a little rough and will not get power or shift on acceleration almost like the transaxle is the problem but after a few seconds or minutes this problems fixes it's self and the van runs and shifts fine. But it does reoccur. We have changed out the Output speed sensor and this weekend we are going to change the input speed sensor and change the distance sensor also on the Trans. Today we are going to replace the PCV valve. please can you tell me if we are on the right track with this. :?[/quote:0085dc34a3]
Could be the VSS/TPS/MAP sensor.[/quote:0085dc34a3]
in Dec of 2006 we had New plugs, wires, coil pack and a new battery installed. got any ideas I'm open to any suggestions. got PVC and additive for gas for the injectors today.
Mar 12, 2007 at 1:24 PM
  • 75,988 POSTS
[quote:1adbdd3d83="dnr79065"][quote:1adbdd3d83="rasmataz"][quote:1adbdd3d83="dnr79065"]I have a 1991 Dodge Caravan ES 3.3L engine with 222.060 miles on it. The Engine will sometimes run a little rough and will not get power or shift on acceleration almost like the transaxle is the problem but after a few seconds or minutes this problems fixes it's self and the van runs and shifts fine. But it does reoccur. We have changed out the Output speed sensor and this weekend we are going to change the input speed sensor and change the distance sensor also on the Trans. Today we are going to replace the PCV valve. please can you tell me if we are on the right track with this. :?[/quote:1adbdd3d83]
Could be the VSS/TPS/MAP sensor.[/quote:1adbdd3d83]
in Dec of 2006 we had New plugs, wires, coil pack and a new battery installed. got any ideas I'm open to any suggestions. got PVC and additive for gas for the injectors today.[/quote:1adbdd3d83]
Fuel filter
How about tranny service -fluid and filter change
Check engine light On?
Try checking the throttle position sensor and Manifold Absolute pressure sensor.
Mar 12, 2007 at 2:23 PM
DNR79065
  • 6 POSTS
[quote:6cacfab6f3="rasmataz"][quote:6cacfab6f3="dnr79065"][quote:6cacfab6f3="rasmataz"][quote:6cacfab6f3="dnr79065"]I have a 1991 Dodge Caravan ES 3.3L engine with 222.060 miles on it. The Engine will sometimes run a little rough and will not get power or shift on acceleration almost like the transaxle is the problem but after a few seconds or minutes this problems fixes it's self and the van runs and shifts fine. But it does reoccur. We have changed out the Output speed sensor and this weekend we are going to change the input speed sensor and change the distance sensor also on the Trans. Today we are going to replace the PCV valve. please can you tell me if we are on the right track with this. :?[/quote:6cacfab6f3]
Could be the VSS/TPS/MAP sensor.[/quote:6cacfab6f3]
in Dec of 2006 we had New plugs, wires, coil pack and a new battery installed. got any ideas I'm open to any suggestions. got PVC and additive for gas for the injectors today.[/quote:6cacfab6f3]
Fuel filter
Try checking the throttle position sensor and Manifold Absolute pressure sensor.[/quote:6cacfab6f3]
Thanks will give those a check or a change and get back to you.
Mar 12, 2007 at 10:16 PM
DNR79065
  • 6 POSTS
[quote:944319b37b="dnr79065"][quote:944319b37b="rasmataz"][quote:944319b37b="dnr79065"][quote:944319b37b="rasmataz"][quote:944319b37b="dnr79065"]I have a 1991 Dodge Caravan ES 3.3L engine with 222.060 miles on it. The Engine will sometimes run a little rough and will not get power or shift on acceleration almost like the transaxle is the problem but after a few seconds or minutes this problems fixes it's self and the van runs and shifts fine. But it does reoccur. We have changed out the Output speed sensor and this weekend we are going to change the input speed sensor and change the distance sensor also on the Trans. Today we are going to replace the PCV valve. please can you tell me if we are on the right track with this. :?[/quote:944319b37b]
Could be the VSS/TPS/MAP sensor.[/quote:944319b37b]
in Dec of 2006 we had New plugs, wires, coil pack and a new battery installed. got any ideas I'm open to any suggestions. got PVC and additive for gas for the injectors today.[/quote:944319b37b]
Fuel filter
Try checking the throttle position sensor and Manifold Absolute pressure sensor.[/quote:944319b37b]
Thanks will give those a check or a change and get back to you.[/quote:944319b37b]
just had tranny replaced in april 2006 with used but all new fluid and filter.
No check engine lite.
Mar 13, 2007 at 1:28 PM
DNR79065
  • 6 POSTS
1991 Dodge Caravan ES 3.3L engine with 222.060 miles on it....................... Ok this time I really paid attention.......... MY MISTAKE NOT THE TRANS!!!!! Van ran good the 12th and the 13th (cooler days) but Yesterday the 14th was in the 70s again, Took the van drove it 5 blocks and filled the gas tank, then I drove it about 5 miles more to my husbands work, shut it off waited for him about 5 minutes. restarted van (Speed Limit is 10 mph in parking lot) got to the security gate and the motor started running a little rough and WOULD NOT GET ANY POWER, So I pulled over to the side put it in park, Motor ran rough enough to give just a slight shake to van NOT MUCH THOUGH, But you knew it was there. waited about 2 minutes the problem went away and van ran fine... No check engine light came on, van did not die but did act like it was going to. have not changed out the Fuel pump yet $173.00 it is on my list though. is there anything else that could also cause this problem? Would like to get this all changed at once. Here is my Baby :cry:
https://images.2carpros.com/forum/automotive_pictures/63666_My_Picture_028300_1.jpg
Mar 15, 2007 at 12:51 AM
  • 75,988 POSTS
Maybe you should have the oxygen sensor check to ensure its operating properly.
Mar 15, 2007 at 9:30 AM
DNR79065
  • 6 POSTS
[quote:88513856f1="rasmataz"]Maybe you should have the oxygen sensor check to ensure its operating properly.[/quote:88513856f1]
Do not know how to check it. All places that can do it is backed up for 3-4 weeks the soonest I could get in would be the 25th or 26th of april. Maybe better to just change it? it is a lot cheaper the Fuel Pump.
Mar 16, 2007 at 7:32 AM
Suggested Repair
Check the throttle position sensor, MAP sensor, fuel filter, and oxygen sensor. The output speed sensor was already replaced, and the transmission fluid and filter were serviced with a used transmission in April 2006. There is no check engine light.
Conversation Summary
A 1991 Dodge Caravan with a 3.3L engine intermittently runs rough, loses power, and seems not to shift, then recovers after seconds or minutes. The output speed sensor was replaced, and a December 2006 tune-up included plugs, wires, a coil pack, and a battery. The owner planned to replace the input speed sensor, a transmission distance sensor, and the PCV valve. The expert suggested checking the VSS, TPS, and MAP sensors, the fuel filter, and transmission service, and asked about a check engine light. The owner later said the transmission was replaced in April 2006 with new fluid and a filter, there was no check engine light, and the problem appeared heat-related rather than transmission-related. The expert then recommended checking the oxygen sensor.
