Do you know if there is some trick to removing the front calipers from a Dodge Grand Caravan? Thank you very much!
Oct 12, 2007 at 9:35 AM
CHEVY22
✓Experienced Mechanic
did you get the bolts out yet ???
jim
Feb 21, 2021 at 8:01 AM
DAVYP54
MEMBER
1 POST
Have the same vehicle. Is it a torx or hex head and what size?
NEW_TO_DODGE
MEMBER
I just did the front rotors and pads on my 2005 Grand Caravan SE. Assuming the bolts are the same, I used a 7mm HEX allen wrench for the caliper bolts and an adjustable wrench for the caliper mounting bracket bolts.
