Do you know if there is some trick to removing the front calipers from a Dodge Grand Caravan? Thank you very much!
Friday, October 12th, 2007 AT 4:35 PM
CHEVY22
MECHANIC
Did you get the bolts out yet?
Jim
SPONSORED LINKS
Sunday, February 21st, 2021 AT 4:01 PM
DAVYP54
MEMBER
1 POST
Have the same vehicle. Is it a torx or hex head and what size?
NEW_TO_DODGE
MEMBER
I just did the front rotors and pads on my 2005 Grand Caravan SE. Assuming the bolts are the same, I used a 7mm HEX allen wrench for the caliper bolts and an adjustable wrench for the caliper mounting bracket bolts.
