Dodge Caravan Windhsield Wiper Fluid Does Not Spray
SJSHER
We just purchased a used 2001 Dodge Caravan with 45K miles. The windshield wiper fluid reservoir is full, but when you press the internal control to spray the fluid nothing comes out on the front or rear windows.
Jan 14, 2007 at 2:46 AM
JDKELLEY
When you press the control, do you hear the pump motor running? If not, the motor may be out. That may something as simple as the motor being disconnected. If you DO hear the motor running, you may have a leak in the line. Check for leakage.
Jan 15, 2007 at 8:05 AM
