I have a 1998 Dodge Caravan, I started having trouble with the transmission one day while driving. It was like I was putting it in neutral and then back into drive. I was having problems getting it into drive, or reverse. When we popped the hood to check the transmission fluid we noticed that there was a pink foam coming from the coolant overflow. We took the cap off the radiator and the same fluid was in the radiator. We are trying to find out what is wrong with it. Have been told that it needs a new radiator and a new transmission cooler. Now we are having trouble finding the transmission cooler. Does this come with the radiator or is it seperate, and if so where would we find it? Any information would help!!!
May 25, 2006 at 5:02 AM
