I have a 1995 Chrysler Voyager LE (3.3, V6), with about 205 000 kilometres (as i live in Finland) on the meter. A few days ago the heater stopped blowing warm air and soon after that the engine started overheating.
The radiator was empty and the fan fuse was out. After filling the radiator, I could see coolant dripping from under the engine. The leak was pretty big, because it emptied the radiator in about 30 mins. The leak was only visible when the engine was running.
Then, all of a sudden, the leaking stopped. At the local repair shop the mechanic couldn't spot any leaking at all. Still, his guess was that it was a head gasket problem.
Now, is there a hose linked to the radiator somewhere on the driver's side of the engine? I couldn't see any leaks from above the engine, and the leakage point is not under the radiator itself. What could be wrong here?
Apr 19, 2007 at 7:14 AM
