DASH QUIT WORKING
HAROLD A
I HAVE A 98 DODGE CARAVAN 3.0 WITH 175,000 MILES. THE DASH GAUGES QUIT WORKING SO I SLAPED THE DASHBOARD WITH MY HAND AND THEY STARTED WORKING. I HAVE HAD TO DO THIS SEVERAL TIMES. DOES THIS MEAN THAT I NEED ANOTHER DASH OR IS THERE SOMETHING ELSE I NEED TO LOOK FOR?
Jul 16, 2007 at 1:45 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a bad connection somewhere in the dash.Might want to remove the cluster and be sure the plugs in the back fit tight with no corrosion or anything to prevent a clean connect
Jul 18, 2007 at 1:12 AM
LEGITIMATE007
  • 5,121 POSTS
[quote:969fa2e4ff="2CarPro Jack"]Sounds like a bad connection somewhere in the dash.Might want to remove the cluster and be sure the plugs in the back fit tight with no corrosion or anything to prevent a clean connect[/quote:969fa2e4ff]
I agree; mine did the same thing and i came to find out that a couple of the bulbs in the cluster were loose. all fixed now :D
Jul 24, 2007 at 3:52 AM
