Can't start my 92 Caravan SE
JWALKER1261
I have a 1992 Dodge Caravan SE with 192,500 miles on it. I recently went shopping and when I returned to my vehicle and tried to start it, the key turned in the ignition but nothing happened. It felt as thought there was no "spring" anymore, and the key did not go back to the running position on it's own? Would love to know what happened and is it something I can fix on my own?
Nov 10, 2007 at 11:30 PM
MERLIN2021
  • 17,250 POSTS
Disconnect and isolate negative battery cable, on tilt columns remove the lever, Remove the column covers, Remove the three tamper proof torx screws, pull the switch away from the column. Release the connector locks on ignition, key in switch and halo light connectors, and remove the switch from the connectors
https://images.2carpros.com/forum/automotive_pictures/62217_Ignition_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Ignition2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Ignition3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Ignition4_1.jpg
Nov 11, 2007 at 12:32 AM
